POINT PRECISION ON SCREEN
(@steve-d)
I am using Carlson Survey 2015 with IntellCAD.
When I "Draw Locate" points from my coordinate file they display as 123.45.
I would like to change the display precision to 123.4567.
Where does this command hide?
Thanks.
Posted : 17/03/2015 3:49 am
(@jimmy-cleveland)
I am using Survey 2008 with embedded AutoCAD. In my version it is under Settings> Units Control.
Hopefully it is in the same location for you.
Good luck.
Posted : 17/03/2015 4:12 am
(@tiglinda)
You can control the precision of your point labels independently of the unit precision setting for cad. In the middle right of the draw-locate screen, in the Point Prompt-Label Settings box, there is a pull down for decimals. You can set what you need there and not change the cad units which can affect other commands.
Posted : 17/03/2015 4:32 am
(@steve-d)
Thank you!
As always, it was hiding in plain sight.
Posted : 17/03/2015 4:59 am
(@jimmy-cleveland)
That's cool! I never noticed that. Thanks!
Posted : 17/03/2015 5:26 am
