I like to overlay the paper (or pdf provided by engineer) copy of the plans over the CAD when prepping stakeout to look for discrepancies.?ÿ But I am reduced right now to doing a screenshot or a snip which distorts the image substantially.?ÿ Does anyone have a recommendation for an affordable program which would allow me to convert a pdf to a good quality jpg?
Thanks
IrfanView. You will have to install a plugin with it in order to view and convert PDF files. Instructions are on the IrfanView website.
The program is a powerful image processing package, but is a little user-unfriendly. The author wrote it for his own use, then shared it with the world, so he wasn't too concerned with making the user interface pretty.
Can you insert the PDF as an xref? We have C3D so I'm not sure if that's a C3D option or if it applies to your version of CAD.?ÿ
I've been using Foxit for my pdf editing for over a year now.?ÿ It's about one-third the price of Adobe Acrobat. It has a few quirks, but mostly works fine.?ÿ It will convert a pdf to jpg. But you can xref pdfs into autocad directly. No conversion needed.?ÿ?ÿ
If you are using Autocad or Carlson Intellicad, you can use PDFIMPORT to import the pdf as linework and block it to align to your cad file.
I use the command PDFATTACH. I'm using Map 3d 2017.
Awesome, will try this for sure with Carlson.
thx
PDFATTACH imports an image which bogs down the cad engine, PDFIMPORT converts the pdf (most of it) to lines that you can block and then align it to your cad line work. I find it works much better.
I have a program called PDF Architect that is pretty reasonable costwise and may do what you are trying to do. They just came out with Version 7 about 2 weeks ago, about a week after I had just upgraded to Version 6. One thing about this program is that you can get the newer version and still keep the older ones.
CamScanner phone app will create an image and send in email as a pdf or jpeg in several qualities and from business allow to crop from card to ledger.
Irfranview is an awesome program.
0.02
have you tried an online PDF to dwg converter?
I used one the other day and it was awesome. Can't say which one as I didn't save the link - bit thick!!!
I expect it depends on whether its a PDF from Cad or a PDF of other origins.
Bricscad will insert a PDF and I trace what I want then delete.
I like Bluebeam Revu.
Convert the JPG to TIF with 2 colors and you can see through it...
Or change the Fade of the JPG to see white crosshairs.
Bluebeam adds the project management functionality to distribute RFIs and plan updates to the design/construction team, which is great if you need that (and everybody else on the team also has it). But as a pdf editor, Foxit is it's equal. And Foxit is well under half the price.
I do this conversion all the time with PDFCreator as a printer.?ÿ When you get to the output/saveas window, select .png for the output.?ÿ
