Magnet Field - Cut/Fill on Map Screen
1 Users
(@ctrunkle)
Having come from using Pocket3d, I’m having trouble locating an option for the map screen that allows you to see your cut/fill to design elevation. This is done by using Survey>Stakeout>Surface Check in Pocket3d but there doesn’t seem to be an easy avenue for the same feature on Magnet. I’ve noticed that when I stakeout linework it will give me my cut/fill to design, but I’d like to be able to see that without staking out anything in particular. Am I missing a simple map setting with this?
Posted : 01/03/2023 2:41 pm
