IntelliCAD Modify by pre selection
2 Users
(@victorstone)
Somehow a intellicad setting has changed. I use to be able to pre select an object so the grips would show, right click, and select and modify command (erase, move, copy). Now intellicad when I go through the same procedure, the pre selected object are deselected, grips not shown after the command, and need to be select the object wanted to modify after the command is enter.
Is there a setting that got switch for this?
Posted : June 2, 2013 7:11 am
(@bow-tie-surveyor)
Try changing the PICKFIRST system variable.
Posted : June 2, 2013 7:26 am
(@victorstone)
That was the setting, thanks.
Posted : June 2, 2013 7:33 am
