Dwg to Pdf . pc3 conversion problem
2 Users
(@james-r-jr-smith-2)
Eminent Member Registered
Hi, I have had Carlson Survey 2022 for several years and recently have had problems with the dwg to Pdf.pc3 option to convert my Dwg drawings to Pdf. The program seams to work as usual but at the send option at the end the Pdf appears for 1 second and the disappears and is lost, gone, no Pdf file. If you know the answer to the problem then Thanks in advance.
J.R.
Posted : 29/08/2024 5:57 am
(@scotland)
Prominent Member Customer
I use PDFEXPORT. It's a better routine than the print routine.
Posted : 30/08/2024 10:40 am
Share:
