Carlson Survey - Mext editor
(@lanceboyle93101)
Reputable Member Registered
Every year I go thru this. Install the latest 2021 version and certain settings are missing. Really, I wonder why I even subscribe the annual maintenance expense when it just causes problems.
1) have to reset the Intellicad Mtext editor to the old type w/?ÿ dialog box, instead of the new type that uses the ribbon.
2) turn off that damn object select popup. I can see what object is selected by the grips. Don't need to go thru another selection process.
Posted : 03/01/2021 2:27 pm
(@ladd-nelson)
Prominent Member Registered
During the installation of the newer versions (I believe Carlson 2020 and later) is a Settings Migration Wizard which permits the migration of settings from a previous version/installation of Carlson into the current version. Complementing this is the underlying System Variable Editor which permits the review/editing/migration of CAD settings as well.
The Settings Migration Wizard should provide ultimate flexibility in terms of what is (and is not) migrated from version to version.
I hope this information helps.
Posted : 05/01/2021 1:09 pm
(@stephen-ward)
Famed Member Registered
Thanks for that Ladd, I just made the jump to 2021 and I need to go back and look at that.?ÿ I'm just happy that Intellicad finally got the message and quit creating a blank drawing every time I open it.
Posted : 05/01/2021 3:10 pm
(@lanceboyle93101)
@ladd-nelson
We used the migration wizard to retain settings. Still reverted to ribbon style mtext editor. One of your cohorts helped me:
From command line type
Mtexted
at options?ÿ type
oldeditor
Posted : 05/01/2021 8:35 pm
Illustrious Member Registered
I tried the jump to 2021. ?ÿDecided to fall back to 2016. ?ÿI think it might have been that mtext issue for the most part...oh well, maybe I will try again in 2033...?
Posted : 08/01/2021 8:40 am
Share:
