Carlson Survey Icons suddenly go B/W
2 Users
(@lanceboyle93101)
Reputable Member Registered
I have both CS 2021 and newly installed (about 2 months ago) CS 2022
THis past week CS2022 icons on ribbon and pulldowns are monotone, but CS2021 remain in color.
Not a big deal as far as workflow goes but I get concerned when things change for no apparent reason.
Annual maintenance fees pd./licensed all yrs. anyone else see this?
CS2021 color icons
CS2022 b w icons
Same workstation, same drawings
Posted : 09/07/2022 11:07 am
(@jon-payne)
Noble Member Registered
Try-
?ÿ Settings
?ÿ Toolbar Setup
?ÿ Check "Color Buttons" at the bottom.
Posted : 09/07/2022 12:21 pm
(@lanceboyle93101)
@jon-payne?ÿ
thanks but not an option at bottom or in the toolbar list.
EDIT:
it is an option on 2021 version
Posted : 09/07/2022 1:53 pm
(@jon-payne)
@lanceboyle93101 Not sure we're on the same page.?ÿ Just in case, I'll rephrase.
Click on the settings pull down menu (very top left corner of your pictures you posted)
When that menu comes down, is there not an option for "Toolbar Setup" about half way down that menu??ÿ There should be and if you select that, it opens up a selection box that looks like this:
toolbarsetup
Down at the bottom of that is the check box for having color or b/w icons.
Posted : 09/07/2022 3:15 pm
(@jon-payne)
@lanceboyle93101 You could try using the command window and type - _tbconfig
That's the command that the pull down menu uses.?ÿ Just in case its hiding somewhere else in the 2022 version.
Posted : 09/07/2022 3:17 pm
(@lanceboyle93101)
CS 2022-
Please type OPTIONS > Display tab and turn off the High Contrast gray scale buttons.
Posted : 11/07/2022 9:13 am
Share:
