I found a cool tool in Carlson that lets you select text and move it with a leader, (Move Text with Leader), but I can't find a setting to adjust the arrow size. I have the arrow size set to .08 under annotation and dimstyle, which works, but they don't seem to affect the arrow the size for move text with leader command. Does anyone know where the setting is hiding?
Thanks
Be sure to check your command line when you first select the command. Usually the first prompt asling you to select an object also has an "O" for "OPTIONS" slection. Enter "O" and see if the setting is not on the resulting pop-up window.
And, what and or where is such a command?
thanks
It gives you some options, but nothing for arrow size.
Edit/ Text/ Move Text with Leader
Thank you. I don't think it is in my version.
Nate
The symbol plot size setting under drawing setup took care of it.
I'm new to Carlson with 2013, so it may be a new feature.
