I have carlson 2009 acad.
I have already used the first 9 Lines on another drawing. SAME FILE.
I am doing another job, same file.
I want to use L-1 again, in a new table.
How can I do that?
I'm going to try to do it. Without updating the other line table.
I want 2 L-1's in the same drawing, with different tables.
I don't want to mess up the other table.
I have spent time before, after messing this up....
In carlson 2013 it asks me if I want to start a new table
OK. Thanks!
All the way up to 2010 it did not ask you if you want to start a new table. You have to "cheat".
Run your first table and place it where you want it. EXPLODE the tables. Now, under AutoAnnotate reset the starting table number to 1. Repeat as necessary. Same procedure for curve tables.
