Carlson .cl File
(@guy-townes)
Can anyone tell me how get a Carlson centerline file into an xml file so that it can be imported into either TBC or a Trimble tablet using Access?
I'm pretty sure I brought a .cl file into a TSC2 that was using Survey Contoller a few years ago and then elevate the alignment accordingly. Both TBC and Trimble Access seem to be rejecting the file.
Posted : February 10, 2019 5:21 am
(@ptortorice)
Iƒ??m not sure if Carlson has a way to export an RXL file but thatƒ??s is what we export from C3D through the Trimble link toolbar.?ÿ
Posted : February 10, 2019 6:36 am
(@stephen-ward)
It's part of the export routine which I believe is under the file menu. It can export an rxl or XML but beware if you're exporting multiple roads. Trimble Access will only see the last road in a multi road rxl file from Carlson but with XML it sees all roads in the file. The work around is to create a separate rxl for each road.
Posted : February 10, 2019 7:46 am
(@guy-townes)
Thanks guys! I appreciate it. Stephen, I don't know how I missed it under the file tab?ÿ ???? I looked there too :)?ÿ
Have a good day!
Posted : February 10, 2019 7:53 am
