4.8 acres building perimeter envelope
4.4 acres under roof
497 corners
113 corners per acre under roof
Beat That !
Looks like a plan view of a Lego scorpion. Kind regards, R.
Some dummy hired an arkytek that grew up in a bubble to design that mess.
This represents some very old buildings attached to some very new ones at our local Masonic Home here in the 46131:
It reminded me somewhat of what was the main Engineering (and arkytekture) building on campus during by college days.?ÿ Same idea as above.?ÿ Start here, add this, then add that, then build something separate, then attach it somehow.?ÿ I found the one hidden (secret) door that would let you get from conglomeration A into conglomeration B, then conglomeration C, but it was permanently blocked.?ÿ You needed a ouija board to guide you to that portal as there were no light fixtures anywhere close to it.?ÿ I'm sure 99.995 percent of all the people working or attending class in some portion of that extended mess had no idea there were catfish being raised in a room on one of the several different second floors.
More impressive given the locale, and visions of FL/GA flitting in and out your line of sight like a fiddler's elbow.
If you are going to lay that thing out don??t worry about how many corners it has, stake the box, if the form crew can??t figure it out then it??s time for a new form crew. Come to think of it there wouldn??t have been enough wood in Florida for me to have staked all the corners of buildings I have staked in the past. Have fun Brad and if they are hubs good luck keeping them plumb.?ÿ?????ÿ
@flga-2-2 it is an existing complex for an ALTA/NSPS to support a refinancing that my rock star crew located. ?ÿI am too old for staking such nightmares. ?ÿThough I did exactly as you suggest on some of these not long ago.
So don't put a bid in to do the construction layout if you aren't up to the task. ?????ÿ
