2 CAD / Carlson Questions
2 Users
ppm
 ppm
(@ppm)
New computer and everything got reinstalled and there are two questions I have for Carlson Survey running on AutoCAD v. 2015.
1. When I open Carlson Survey it always comes up with a blank drawing "Drawing1.dwg". It used to come up without that, and I cannot figure out how to turn it off.
2. When I insert a block with attributes, it pops up in a little window where you can insert the info. But it used to just come up in the command prompt, which I like way better. (I did a google search and ATTDIA did not seem to do it).
Posted : October 17, 2023 1:23 am
blitzkriegbob
(@blitzkriegbob)
For the first, try the command Startup. Either 2 or 3 is what you might want. For the second, there are two variables you need to set. Attreq should be set to 1, Attdia should be set to 0.
Posted : October 17, 2023 2:05 am
