D rtk dji and base trimble r8
1 Users
Geoatacama
(@geoatacama)
I am new here and I have doubts about the connection between a trimble module r8 and an rtk module of dji (D rtk) or one emlid reach m +.
So far I have worked in PPK mode with post process correcting the point in which the image was taken.
But I want to install a Lidar module in a Matrice 600 pro hexacopter and in a UAV that I built with a pixhakw4 driver.
To achieve better stability and a more accurate flight I want to install the matrix 600 a D rtk module and the other has an emild reach + installed.
The flights I want to correct from a known point (RTK) a base module R8 with internal radio and bluetooh and trimble controller Tcs3 with the programs scs900 old version and fieldgenius new version and also I have a radio tdl450h
the problem is as follows, so far I can not connect the base R8 or with reach or Drtk to make the corrections
I have researched about creating a server or RTK network, but many of the jobs I have done are in areas without Internet network, it may work in the city but not in remote areas
My question is if you can create a "false" wifi network, a modem, laptop and telemetry kit for the modules to make corrections
the works require only to move away 500 meters from the point where the base is installed, for safety
thanks for the time and greetings
Posted : January 28, 2019 7:35 pm
