RTK error "Code"
(@neilrick)
Eminent Member Registered
Question about error codes on Base/Rover setup. ?ÿI just noticed recently that the rover was giving an error code called "Code." ?ÿIt seems related to fixed, float, autonomous. ?ÿThe Rover would cycle through, and seems Code is after autonomous. ?ÿWe use a Base set on a known point, with Rover. ?ÿAny ideas what this error means?
Posted : 15/01/2022 5:09 pm
Possibly it could mean the receiver is locked to a GNSS code modulation signal but not to the carrier(s).
Posted : 15/01/2022 6:18 pm
(@robertusa)
Reputable Member Registered
Which ?ÿbrand equipment?
Posted : 17/01/2022 9:54 am
(@rover83)
Noble Member Registered
Most receivers will get a code solution before the RTK engine steps in and uses the carrier phase to resolve the RTK solution. It's pretty routine
Not sure why it is throwing an actual error code, though. Maybe trying to measure before the receiver is fixed?
Posted : 17/01/2022 9:59 am
Share:
