Hi all
I have a problem converting 3 Leica static files into RINEX format.
Background
From a small static campaign spanning two days with two dozen .m00 files generated, 3 of the stations (files) have failed to convert into RINEX format.
Within Infinity 3.2.1 i can view and manipulate the files without issue however when exporting these 2 dozens files into rinex, 3 will not export.
I was hoping a member with a more recent version of Infinity could try exporting into RINEX for me.
Thanks
What, if any, error messages do you get?
Was the receiver software the same version for these files as the ones that did convert? If everything used the same software version, then it would seem unlikely an update would fix it.
Was there anything different about those three sessions?
v3.2.1 is not super old, so I doubt that a newer version would make a difference for RINEX export. I too would be interested in the error messages, if any. I have seen Infinity (and some of the controllers) put out some bogus RINEX files in the past.
Have you tried WinTEQC? I use that for most of my conversions or manipulations these days. It will allow you to view the m00 file before conversion so you might be able to see if there is a something going on with the session.
No error messages
Yes
No, the previous session and the following session exported into Rinex without issue.
I have almost no experience with WINTEQC and wouldn't know where to begin manipulating data.
Contact your Leica dealer or call the Leica support line.?ÿ Even if you are not under a service contract, this is an issue they should address.?ÿ One of the options that I used with Leica GPS was to have them LOG directly to RINEX.?ÿ If you load WinTEQC, and select the *.M00 files, if that is one of the supported formats, it will convert the file to RINEX for you.
with the new version shouldn't be a problem
