Post Process GNSS K...
Post Process GNSS Kinematic Surveying
(@horhe)
Who knows how to operate H32 Hi-Target GNSS RTK System using Post Process Kinematic Mode.?
Posted : 17/03/2015 7:03 pm
(@spledeus)
The Chinese?
I have experience with PP Kinematic with Topcon and Novatel. Oh and I did some way back when with some old Magellan L1 units. Concept is similar in all of them. What are you seeking?
Posted : 18/03/2015 9:31 am
(@roveryan)
> The Chinese?
So what's the accuracy for L1 kinematic for hor & ver values?
Posted : 19/03/2015 12:41 am
(@horhe)
Im Seeking of how to execute it in the field and process it in the office..I explore it already but I have some difficulty of finding it..There's no manual in executing it in PPK mode..But there's a manual for processing the data in the office..
Posted : 19/03/2015 5:51 pm
The ProMark 3 is capable of 1cm in PP stop & go kinematic. The same as RTK except it isn't real time. One advantage is you can run as many base receivers as you want.
Posted : 19/03/2015 7:04 pm
This is general because I'm not familiar with your equipment.
You need at least one receiver operating in static mode. This is your base station.
You need to somehow initialize your rover. The traditional method was use an initializer bar for a specified length of time. Another way is to do a known point initialization. I bet most equipment is capable of doing an on-the-fly initialization which is the simplest because you simply start surveying. You need to maintain satellite lock at all times or do a new initialization.
The rover receiver stores a file. When you download the files and process them the software should recognize the kinematic observations and process them against your static base.
Posted : 19/03/2015 7:14 pm
(@horhe)
Hi-Target uses Hi-RTK Road (For Road Construction) software which is installed in the controller, Is this capable in conducting Post Processing ? I can't find the initialization mode style in the software.
Posted : 16/04/2015 9:20 pm
No, post processing is done on the computer you download the files too.
The controller needs to be capable of doing post processed kinematic.
Posted : 17/04/2015 5:29 am
(@horhe)
What Post Processing Kinematic software is compatible for Hi-Target Controller.?
Posted : 19/04/2015 11:11 pm
