We are trying to connect to our Hiper VR from a laptop to use with our gpr, but it keeps asking us to enter a PIN to pair to the device. Has anyone had this issue and how can we turn off the PIN?
Posted : 03/05/2023 1:48 pm
Yes, some apps and OS require an authentication code. By default Topcon ships with no code. However you can assign a code manually using TRU.
Posted : 03/05/2023 2:04 pm
@leegreen so to remove the pin I would need to do the same thing? Go into TRU?
Posted : 03/05/2023 4:15 pm
Thats correct. Like I said you most likely don't have a PIN assigned to the device. It's your app that requires one. Either way you can change it with TRU.
Posted : 03/05/2023 10:11 pm
I always try 1111 or 1234
Posted : 05/05/2023 6:07 am
