I did a 2.5 hour observation today and had submitted for an OPUS Solution. It came back OK. So I decided to split it tonight just in case I might get an OPUS-RS since it was earlier in the day. OPUS RS took first 1/2 but not the other, so I ran it through teqc. I just submitted it and had an OPUS-RS solution in my inbox 1 minute later.
WOW, WOW, WOW is all I can say.
Latitude tolerance 0.006m & 0.005m, SPC Northing .027 & .017, took 91% of it, and the OPUS solution was somewhere in beween.
Longitude tolerance was 0.005m & 0.004m, SPC Eastings .862 & .866 only took 44% of it, and again OPUS solution was in between.
OPUS-RS Ortho heights 265.577m 0.020m & 265.522m 0.023, OPUS in between at 265.551m 0.018m, in between.
No local CORS used so I will resubmit tomorrow for probable tighter solutions.
I could wrap up the GPS portion of this project tonight, if I wanted to, but I am not going back for more field work until Friday..
My mistake, I missed that I had submitted the same file earlier, and the first solution came back right after I resubmitted. The second solution came back with same results this morning as I had shut my email down last night. I thought it was too good to be true.
