GNSS & Geodesy
6
Posts
3
Users
0
Reactions
0
Views
Hello,
Can i use Corrections from IGS stations however the nearest igs station is 600 km .Could you help me please.
Posted : 09/07/2021 10:17 pm
600 km is much too far to get best accuracy. You would probably get measurements that differed by decimeters from day to day.
Posted : 12/07/2021 6:21 am
@bill93?ÿ
Thanks for your reply
So the realtime stream correction from IGS stations depend on baseline distance not common satellite ?!
Thanks for you support
Posted : 15/07/2021 1:08 am
Only satellites common to the base and rover are useful.
The iono/tropo corrections obtained from the base are most accurate close to the base, and less accurate with larger distance.
Posted : 15/07/2021 7:48 am
Take a look at AUSPOS AND UNAVCO
There might be a station closer
Posted : 15/07/2021 8:34 am
Thanks , i live in Egypt so the nearest igs station in cybrus?ÿ
Posted : 16/07/2021 12:58 am
