Geodesy and GPS Cla...
Geodesy and GPS Class - Second Installment
(@thomas-taylor)
Here is the second module in the Geodesy portion of the class. The GPS (should be GNSS at this point, but when I wrote it......) modules may be more practical as there is a description of how GPS works, error sources, mitigating error sources, planning and conducting geodetic and RTK surveys and a fairly detailed description of least squares adjustments.
All comments are welcomed.
AM_Topic_1_b_.pdf (1.1 MB)
Posted : 23/07/2017 5:03 am
(@superfly)
I like it thanks for taking the time to do this.
Posted : 24/07/2017 9:05 am
(@crashbox)
Thank you very much for posting these.
Posted : 24/07/2017 9:22 am
(@ncspiralguy)
"GLONAS" should be "GLONASS". It's GLObal NAvigation Satellite System, and similarly in Russian, except the first S is Sputnik.
Since a meridian is not a semicircle, but a semiellipse, you may want to mention that the latitude is the angle between the tangent to the ellipse and the axis. It is not what you get by measuring angle on a circle and stretching it. If that goes in the next installment, that's fine.
I came up with names for the ends of the ECEF axes. +x is Benin, -x is Howland, +y is Bengal, -y is Gal?­pagos, and of course +z and -z are Arctic and Antarctic.
Looks good!
Posted : 25/07/2017 5:34 pm
