Difference of Singl...
Difference of Single base NTRIP and Post Processing against same station
2 Users
(@gisjoel)
Hello,
I use Post Processing differential using Trimble Pathfinder Office holding the OPUS derived NAD83 (2011) Epoch 2010.0 position in my workflows.?ÿ The same station is also serving in realtime a NAD83 (2011) Epoch 2010.0 position streaming.?ÿ Given my device (a Geo7x with Zephyr 3 base) is carrier based and limited (not survey quality), isn't my finally resolved position in post processing the same as a point resolved by streaming??ÿ In the former workflow, an averaged position of say 30 positions are individually corrected and averaged, while the second workflow (via NTRIP) is likely getting each of the positions in realtime NAD83, and then averaging for a point.?ÿ?ÿ
Thanks
Joel
Posted : 29/10/2019 6:33 pm
(@shelby-h-griggs-pls)
Probably or at least close to same results. Not familiar with gear or software you mention, HOWEVER, can't you get a real time position and a post processed position on same point and compare the two to answer your question?
SHG
Posted : 31/10/2019 8:09 am
