Connecting R8 with ...
Connecting R8 with GSM Modem to AT&T Network
2 Users
(@scott-bordenet)
Reputable Member Registered
I am trying to connect to the AT&T cellular network with Surveyor Controller and R8 model 2 connected via bluetooth. I am using username I S P at C I N G U L A R G P R S dot XXX and password CINGULAR1. I have also tried WAP at C I N G U L A R G P R S dot XXX/CINGULAR1. Note XXX = COM I keep getting "APN Activation sequence failed. Check APN settings...."
I have tried going through AT&T. They said they made sure the IMEI number that my device was reporting was accepted on their network, so the problem must be on my end and to check with the manufacturer.
Any ideas or advice?
Scott
Posted : 18/02/2016 6:59 pm
Famed Member Registered
Scott Bordenet, post: 358582, member: 10097 wrote: I am trying to connect to the AT&T cellular network with Surveyor Controller and R8 model 2 connected via bluetooth. I am using username I S P at C I N G U L A R G P R S dot XXX and password CINGULAR1. I have also tried WAP at C I N G U L A R G P R S dot XXX/CINGULAR1. Note XXX = COM I keep getting "APN Activation sequence failed. Check APN settings...."
Scott
On my R10 I have the access point name set to I2GOLD, CID is 1. username and password are blank.
Posted : 18/02/2016 7:16 pm
Share:
