Connecting EMLID RS...
Connecting EMLID RS2 thru Blue tooth to the TDS Survey Pro V4.2.1
2 Users
(@cdrmhm)
I currently use Tripod Data Systems Survey Pro application version 4.2.1 that I run on a Trimble TSC2 Data Collector, works great with my total station.?ÿ However, I recently purchased the Emlid RS2 for running as a base and rover system, and when I try to connect the RS2's bluetooth output from the rover to the Survey Pro GNSS input, I am unable to see the RS2.?ÿ The Survey Pro program has a pull down menu which list several different input sources (Trimble, Leica Sokkia, Thales, Topcon, & Novatel) along with their different device models. My question is there an update for the Survey Pro that will allow my RS2's NMEA output to be recognized??ÿ
Posted : 16/01/2021 10:10 am
(@jose-duran)
Hi Michael,
I'm using fieldgenius with reach2 as a rover to connect to CORS. I use NMEA via Bluetooth settings to receive corrections to my data collector. I bet this could be the same for survey pro.?ÿ
Configure first the rs2-data collector Bluetooth connection then NMEA settings on survey pot.
I hope this can work for you.
Posted : 16/01/2021 12:17 pm
