Aloha,
Trust all is well at SurveyConnect!
I am wondering if there is an easy way to readjust a centerline that was created with many arcs? I also want to adjust the offset points that is associated with the centerline.
Thought I'd ask here first before deleting the points and recreating them again after adjusting the centerline arc that forms an oblong circle.
Any thoughts for seasoned Carlson Survey users will be very much appreciated. 🙂
Have a wonderful Friday and awesome weekend everyone! Aloha!
Some days a best fit solution to explain and describe the physical location of a centerline is as good as it gets.
You have to decide what your tolerance of deviance from actual path of the calculated alignment and the physical location is allowable.
Locally many roadways have no monuments and reducing their location to the lowest number of lines and arcs can smooth out location that may vary in several tenths to several feet depending upon the importance of the path being described.
good luck 😉
