X90 opus help
(@jimth)
I bought two units a few months back and so far have been pleased with the reliability. I bought them primarily for elevation certificate preparation. Nothing like having to run a level loop for 3 hours. My question is this...
On a 2 hour observation I can upload to opus and get a solution back in a matter of minutes. This happens the same day within a few hours of the observation. On rapid static I have to wait until after midnight to upload and get an opus solution. Oh I can upload a rapid static obs the same day but I only get error reports returned. The same rinex file uploaded the following day brings back a solution within minutes.
Is this normal?
Posted : November 23, 2014 7:06 am
(@sirveyr)
Quite normal. I get the same thing. I believe it has to do with lack of availability of data from the multiple CORS required for OPUS-RS.
It is not receiver specific. My GRX1 and HiPer V's do it as well.
Posted : November 23, 2014 7:18 am
(@radiored)
Wait a day. It work then
Posted : November 23, 2014 7:58 am
(@jimmy-cleveland)
I have the same issues with my two OPUS X90 receivers as well as my two Topcon Hipers.
I have started running 2 hour sessions for most of my elevation work. I use OPUS RS as a blunder check when doing horizontal control.
I have not done it yet, but you can always split the 2 hour files up into smaller files and use OPUS RS for additional data analyis.
Posted : November 23, 2014 8:45 am
(@mark-silver)
And it is location dependent too. If you are surrounded by hourly CORS stations, then there is a really good chance that the OPUS-RS solution will be available quickly.
What is happening is:
"OPUS-RS needs more nearby CORS available than OPUS-Static (which only needs 3 stations and for static they don't need to be that near.)"
So the Static solution needs only 3 stations and they can be much farther away.
In some areas, like the center of Michigan for example where there is literally a hourly reporting CORS station on every corner in every town (okay, maybe I am exaggerating a little bit,) OPUS-RS is a dream come true.
Other places, like Utah or Wyoming for example, not-so-much.
Thanks for purchasing a X90-OPUS! Hopefully it is serving you well.
Mark
Posted : November 23, 2014 4:40 pm
Speaking from the Big Open, in use static for "rough" delegation control, but not OPUS, that's too rough;-)
Posted : November 23, 2014 7:22 pm
