Selecting different...
Selecting different point ranges in TBC
Rob O'Malley
(@rob-omalley-2-2-2-2-2)
TGO allowed us to remove groups of selected points or keep certain points, but I don't see that option in TBC.
I.E. I have a large group of points but I want to select 100-200 and 6000-7000, not the points in between.
I'm sure its got to be some sort of ALT SHIFT function but How do I do that?:-S
Posted : February 3, 2012 9:36 am
Chan GePlease
(@chan-geplease)
I don't have TBC, but every selection process out there would just place a comma in between "100-200,6000-7000".
Otherwise wouldn't the workaround just require doing it twice. Which seems like typical Trimbleese language.
Posted : February 3, 2012 9:45 am
Rob O'Malley
Wayne, you'd think Tribleese would work that way but it appears they completely remove the old "select by range" function that TGO had. At least I haven't found it yet and a class I took wasn't able to find it either.
Right now I'm limited to highlighting the necessary points with the shift command in a side bar and I can't "remove the current selection" or "keep the current selection"
Posted : February 3, 2012 10:47 am
dave-lamberton
(@dave-lamberton)
Change to "100...200,6000...7000" it takes a little getting used to.
Posted : February 3, 2012 12:26 pm
wildt2
(@wildt2)
yep, need those dots because you can have point number with dashes in them, like, 100-200 could be a point number.
Posted : February 5, 2012 4:20 am
