"Is it weird..
8 Users
(@jitterboogie)
...That the company I work for doesnt own a Level and the only thing I use my level rod for is dipping manholes?"
Asking for a friend.
Posted : March 31, 2022 8:05 am
I have not owned a level since purchasing a total station.?ÿ Have no need for one for the work that I do.
Posted : March 31, 2022 8:30 am
(@frozennorth)
Yes, I find it a bit weird, especially since you can pick up a good used level for the price of a few GPS batteries.?ÿ Always worth having around as a sanity check.
Posted : March 31, 2022 8:35 am
(@dmyhill)
Posted by: @jitterboogie
My experience is that correctly used a good total station will out perform any level you might find in a typical surveyor's truck.
Yes, I know you can use different attachments and an invar rod, etc, etc, etc...but that is not usually done in the real world. We used to call it "trig leveling" using the total station and a fixed height rod, but whatever you call it, it works.
That said, I would not feel comfortable not having one. For one, sometimes it is the easiest and best tool for the job, and while you could use a total station, it would be a waste of time in those cases.
Posted : March 31, 2022 10:49 am
(@jitterboogie)
@dmyhill?ÿ
that's kind of where I am, esp for when the BM are close and easily accessible.
Posted : March 31, 2022 11:19 am
 Joe
(@one-cup-o-joe)
He!!, I still carry my p-gun!
Posted : March 31, 2022 12:07 pm
(@sergeant-schultz)
I have a high end Topcon autolevel. I bought it on Ebay for $160.?ÿ Pegs perfectly ( or as perfectly as I can see).?ÿ Ran a 1.5 mile loop with a shipload of turns.?ÿ When I read the rod I round the half hundredths to the even .01.?ÿ Closed by .02.?ÿ Can't beat a level for comfort level in vertical control.
Posted : March 31, 2022 2:48 pm
I have a level at my current job but it hasn't been used for several years.
At my last job we did a lot of construction staking (commercial buildings) and we used the level quite a bit. I felt that it gave people more confidence in the results. I could show them the book and how the arithmetic worked. Couldn't do that with total station data so easily. That show had value in that setting.?ÿ Construction staking is partly theatre. If the crew loses confidence in the surveyor work will grind to a halt. They will start asking for 3 times more staking than they really need and question everything.?ÿ?ÿ
Posted : March 31, 2022 3:02 pm
(@stlsurveyor)
It should be considering you can complete a survey with one...like when the batteries die or some A-hole forgot to bring a DC...stadia...book every shot. Been there done that...
Posted : March 31, 2022 4:27 pm
(@jitterboogie)
@stlsurveyor?ÿ
I'm sure glad you candy coat it.
The soft souls whom field survey might get their feelings hurt....
still owe you a beer or coffee when you roll through DEN
Posted : March 31, 2022 6:57 pm
