Ground Surface Sett...
Ground Surface Settlement Around Seattle Tunnel Project
8 Users
(@avery)
Map for those that are interested:
Not fun times for the project engineers and surveyors.
Posted : December 12, 2014 1:57 pm
An overview of the Harris and Galveston counties' subsidence.
Posted : December 12, 2014 2:30 pm
OMG!!!!!!
Referring to both links above.
I had no idea that the real numbers were anywhere near this big.
Posted : December 12, 2014 4:11 pm
(@joe-the-surveyor)
Any idea of the cause?
Posted : December 12, 2014 6:34 pm
(@eric-bowles)
(@spledeus)
Our area appears to have a non-uniform subsidence rate that varies between 1-3 mm/year or 4-12" a century.
Thank you for this as I will be passing it along to some of the folks designing the sewers in the area. Big pipes are often laid flat and if one end drops at 12" and the other at 4" we may find some sewers flowing the wrong way.
Posted : December 13, 2014 7:58 am
Note that the shaft is across the street from the Puget Sound. And that whole area of waterfront Seattle is built on reclaimed land. It was originally a tidal flat.
Posted : December 13, 2014 8:14 am
(@ctompkins)
Monitoring the Surface
Just out of curiosity do you know how they are monitoring the surface? What surveying methods are they using to determine the amount of settlement?
Posted : December 15, 2014 5:36 am
Not specifically, but I proposed on a similar project in Portland a few years ago. It was to involve regular differential levelling of surface benchmarks established cross section style along the alignment route. Frequency of the monitoring was increased in the immediate area of the active boring work.
Posted : December 15, 2014 7:08 am
