Anyone still using ...
Anyone still using TGO able to use Geoid 12?
(@dan-patterson)
I am still running Trimble Geomatics Office. I downloaded Geoid 12 and loaded it onto my TSC2 on which I run survey controller and I was able to pick that as my geoid model in a new project with no problems.
However, when I download the Geoid 12 GGF file into the proper directory (c:program filescommon files/trimblegeodata) it does not show up as one of my choices under TGO project properties - coordinate system settings - geoid model. Is Geoid 12 not recognized by the software? I do not see why this wouldn't work. I recall going through the same process with Geoid 09 and it worked fine. Am I missing a step?
I already tried importing a job using this geoid to see if that would help the software identify it, but it did not work and I was forced to revert back to Geoid 09.
Posted : August 24, 2012 4:28 am
(@john1minor2)
Dan
Go into the coordinate system manager in TGO then the edit tab and select add geoid model
Posted : August 24, 2012 6:15 am
(@glenn-borkenhagen)
Like John said -
Looks like you need to do Step 2 of these instructions.
Just substitute GEOID12 (or GEOID12A) for GEOID09.
GB
Posted : August 24, 2012 6:19 am
(@dan-patterson)
Like John said -
Thanks a lot! It has been a while since I have done that. I had the Geoid file in the right place I just hadn't added it to the list of available Geoid models.
Posted : August 24, 2012 6:29 am
