Off-Topic Chit Chat
1
Posts
1
Users
0
Reactions
0
Views
Someone was asking about power inverters last week....
Here's my setup.
12 Volt Deep Cycle Marine Battery with 105 Amp Hours Capacity
800 watt (1600 watts peak) Cobra Power Inverter.
I have it hooked up to a bunch of temporary light fixtures with compact fluorescents and LED Christmas Lights for working on my spec house.
Surprisingly, it will run my 2 HP Ryobi Skll Saw that supposedly draws 13 amps (at 117 volts AC), but only if I disconnect everything else.
13 AMPS X 117 Volts = 1521 Watts so the skilsaw works fine as long as you don't run into a big knot; then the power will cut out for about 2 seconds.
It's certainly more convenient than running a generator all day.
Posted : November 17, 2010 7:23 pm
