Trimble R10/R12 issues
15 Users
(@k-huerth)
Trusted Member Registered
A few months ago we had to send an R10 back to Trimble to have them fix the antenna connector, it basically came apart when unscrewing the antenna at the end of the day. I was out last week using an R12 (that is less than a year old) and when attaching the antenna I noticed it was loose, and we have the same problem. The connector has broken away from the housing, is anyone else having these problems or is our field crew too rough with them?
Posted : 15/12/2021 8:48 am
(@350rocketmike)
Noble Member Registered
That happened to one of our R10's but it was used by the one guy known to be really rough on stuff.?ÿ
Posted : 15/12/2021 8:54 am
(@fairleywell)
Estimable Member Registered
Are your crews taking the antenna off prior to putting the receiver in the truck??ÿ I see a ton of broken antenna connectors where crews throw the receiver, with antenna and still attached to the rod, in the back of the truck. That will not only break the connector, but it will break the housing as well.?ÿ It's fixable, but not cheap.
Posted : 15/12/2021 10:03 am
(@k-huerth)
@fairleywell I once saw the crew driving down the road with the R10 still attached to the rod hanging out the window....nothing would surprise me at this point, I was kind of hoping this was a common problem and I wouldn't be able to fault the crews.
Posted : 15/12/2021 10:24 am
(@jitterboogie)
Famed Member Customer
It's likely the abuse.
I saw the coworker's gear and was absolutely shocked to find out it's not even a year old.
My Surveyor's gear? Immaculate. He's not 100% field but still. These things are preventable, and the list goes on.....
Posted : 15/12/2021 10:34 am
(@azweig)
Reputable Member Registered
It's a fairly common issue, but mostly due to not taking the antenna off when putting the rover away or it falling over or throwing it in the truck still attached.
Posted : 15/12/2021 11:46 am
We have a good group of guys that take care of stuff. Our r12i lost the internal clip off the antenna and the tech remarked it was a 'common problem'. The following month the radio board fried.
I have used trimble since the all night dos processing days. I am not at all impressed with the design or workmanship of their new stuff. Great features, but only when they work. I also believe the vendor structure has resulted in poor service in some areas. They better get on it or a drop in market share is coming.?ÿ
Posted : 15/12/2021 12:03 pm
(@fairleywell)
@thebionicman I work for a dealer and that is one of my worries.?ÿ?ÿ
Posted : 15/12/2021 12:19 pm
@thebionicman I 2nd this.
The TSC3 was the pinnacle, tough, nearly trouble free. TSC7 was too heavy and ate batteries. TSC5 is much better on the battery but Android is not that great and the device is kind of annoying some times. The stylus takes a very heavy touch and it keeps dropping Bluetooth connections to the receivers, especially older ones.
Iƒ??ve been wondering about Leica which is a weird feeling.
@dave-karoly I have been impressed with Leica processing software. Looked at some hardware last night and it looked slick. Interested to see how tough it is in the field...
Posted : 15/12/2021 12:36 pm
(@fairleywell)
The biggest issue that I hear about with Leica is the support.?ÿ I know that the company that I work for has 10 tech support people dedicated to handling the day to day tech support and several others that can handle advanced support cases.?ÿ Most issues are taken care of immediately while the advanced cases are mostly handled in a day or two.?ÿ
Posted : 15/12/2021 1:23 pm
(@lukenz)
Honorable Member Registered
@thebionicman?ÿ
At least as tough as Trimble in my experience, both robots and GNSS.
Lecia field software is quicker once you set it up with hot keys but Trimble access simpler to use on day one, neither is better just different approaches
Posted : 15/12/2021 5:47 pm
(@lukenz)
@fairleywell?ÿ
That's just a dealer problem not a hardware/software one. A good dealer is far more important that choosing team green or yellow.
Posted : 15/12/2021 5:48 pm
(@lee-d)
Our guys can tend to be pretty tough on their gear and we've experienced a very high failure rate on the R10 antenna mount. As great a design as the R10 / R12 is, why did they put that crap antenna in there? Good old TNC worked great for decades.
Posted : 16/12/2021 9:12 am
(@totalsurv)
I think the antenna thing is a well known issue generally caused by?ÿ over tightening the antenna. I warned our crew when bought new.
Posted : 16/12/2021 10:15 am
Share:
