Total Station Skill Heat Map
18 Users
(@half-bubble)
Noble Member Customer
Of the overall population of survey personnel at all levels, who still uses a total station?
This would make an interesting heat map. Who uses one most days, and who has the skill at all?
Perhaps a third layer showing places where there are crews not using total stations at all.
Posted : 26/01/2021 7:46 pm
 seb
(@seb)
Reputable Member Registered
Sure I use the RTK a lot but the robotic total station comes along in the car to every job and gets used frequently. Trees and buildings have a habit of being inconveniently placed for RTK purposes.
Posted : 26/01/2021 8:58 pm
Everyone I know personally still uses a total station in their work.?ÿ They may use GPS as their primary tool for certain jobs but they still use the total station for close work, lot jobs and to get precise locations that GPS simply does not work for (too much cover, etc.)
Posted : 26/01/2021 9:08 pm
Famed Member Registered
In western Washington and Oregon probably more than 75% of all survey work is done with a total station. In fact, there are a number of companies in the business that do not own GPS at all.?ÿ Not that long ago I worked for an outfit that had 6 crews, all well outfitted with the latest Robotic total stations. The 6 crews shared a single base-rover GPS pair. Only a couple of the PCs were even capable of running the GPS.?ÿ
If you are doing building settlement monitoring or commercial building construction layout anywhere, it should be mostly with a total station. You just aren't going to get the kind of precision required with GPS.
Posted : 26/01/2021 9:58 pm
(@sireath)
Total Station is still in use quite often in engineering work. You can't use a scanner to do staking.
While the question is asked with good intention, I think that Surveyors should not be worried about knowing how to use the tool but rather knowing which tool is perfect for which job.?ÿ
Posted : 26/01/2021 11:58 pm
(@field-dog)
Noble Member Registered
I'd say it's nearly 50/50 (TS/GPS) here at Orange County Public Works in Orlando, FL. All TS work is done by an ST (Survey Technician). I never see anyone "bucking in" or "double centering" anymore.
Posted : 27/01/2021 2:15 am
(@mike-shepp)
Trusted Member Registered
GNSS is the first tool I take out of my ƒ??tool boxƒ?, but in my opinion there are a lot of tasks where the robot is simply fasterƒ??construction staking for example.
Posted : 27/01/2021 3:59 am
Illustrious Member Registered
Total Station? What's that? Gas Sta? say, would you bring me a cup of coffee, and a bag of peanuts, if you are going......
Posted : 27/01/2021 4:27 am
 jph
(@jph)
I wouldn't even know how to do our work without using a total station.?ÿ Too many trees, bad cell coverage, etc.?ÿ I like having it and using it when we need it, but I'd guess it's 90/10% TS/GPS here.
Posted : 27/01/2021 6:22 am
(@half-bubble)
The intent of the question is perhaps not clear or fully informed. Let me add that I am curious about the anecdotes I have heard for the last 10 years about crews west of the Mississippi and generally in the Great Basin where a guy could start doing oil and gas fieldwork and be considered a surveyor and working under supervision and be doing work that is recorded and yet never have to touch a total station thanks to the open skies and modern technology. When all of that field survey experience is included in the mass noun of "SURVEYING" what percentage of work hours are still total station work, and what is the rate of change?
When everyone has a Javad, who will know how to work a total station?
Posted : 27/01/2021 9:14 am
(@paul-d)
Honorable Member Registered
We use a total station for every job. There is far too much detail to be located by GNSS and I would never layout a structure with RTK. RTK is used to establish coordinates and set pair points where traversing to the area from the rest of the project doesn't make sense.
Posted : 27/01/2021 9:24 am
I bet we all have had jobs where pulling out the steel tape is the fastest and best method of doing what needed done.
Posted : 27/01/2021 9:44 am
 jph
(@jph)
@holy-cow
What is this steel tape thing you speak of?
Posted : 27/01/2021 11:50 am
@jph
Kids!?ÿ You buy them books and they eat the pages.
Posted : 27/01/2021 12:32 pm
(@jitterboogie)
Famed Member Customer
GNSS and SX10
So yep.
Posted : 27/01/2021 1:31 pm
Page 1 / 3
Share:
