Topcon GTS-313 Battery
(@btaylor)
Estimable Member Registered
I have aTopcon GTS 313 battery that won't charge. I thought it was the charger and got a new charger, but it still doesn't charge when I plug it up. The life of the battery has seemed ok when I use it, lasting most of the day before going dead. I don't have another battery to test the chargers with, but assume the charger is ok. Has anyone ran into this? Thank you
Posted : 11/02/2022 9:14 am
Does the battery have a fuse you can check?
Posted : 11/02/2022 9:51 am
(@russ455)
There should be an internal fuse and probably a thermistor also.?ÿ
Posted : 11/02/2022 4:18 pm
(@btaylor)
Ok, I'll try to open it up and check for a fuse. I'll post any update on it. Thank you
Posted : 14/02/2022 6:11 am
(@btaylor)
Ok, so I had to order some fuses because they're a weird size and are not carried at any local parts stores. The fuse that was in it didn't look bad, so I didn't know if that would fix it or not. Anyway, I changed out the fuse and the light on the charger still does not come on when I plug the battery in. I tried the original charger and the new one (From China). Do you guys have any other ideas? I don't know much about the makeup of these batteries, so if you could dumb down any instruction, that would be helpful. Thank you again.
Posted : 22/02/2022 2:56 pm
Share:
