Topcon gt-505 error
2 Users
(@ouchjamoi)
Active Member Registered
good day everyone... im using topcon gt-505 and i am having this problem that when i run the programs it just stops at "Executing program mode..."
hopefully somebody can help me with this problem cause i work at a government agency and we are busy doing topographic survey these days for future government projects...?ÿ
Thank you everyone...
Posted : 31/10/2020 11:39 pm
(@russ455)
Estimable Member Registered
Are you trying to run Magnet Field onboard? ?ÿ The onboard programs are not needed if running as a robot?ÿ
Posted : 01/11/2020 11:39 am
(@russ455)
Hit Enter too fast...... ?ÿFirst think to try is the reset button under the cover for the usb connections.
Posted : 01/11/2020 11:41 am
(@ouchjamoi)
@russ455 yeah the Magnet Field on the instrument... even TS Shield is stock at executing program mode... im doing topographic survey using magnet field...
Posted : 01/11/2020 10:55 pm
(@ouchjamoi)
@russ455 i did try those... few times it worked... but now it doesn't work anymore...
Share:
