Tips & Tricks for field technicians
25 Users
(@kevin-slottke)
Eminent Member Registered
I had a guy like that. Didn't realize until I went out one day to meet him. He didn't see me. He was hardly stopping to take shot.
Great advice!
Posted : 21/09/2024 2:52 am
(@kevin-slottke)
Really great stuff! Keep it coming.
Thank you!!
Illustrious Member Registered
When levelling as rodman, position yourself behind the rod and face the instrument. That way you get the rod squared up to the line of sight. If you stand off to the side, not so much.
When booking level notes - say the reading to your self out loud, then write it down. Close your eyes and think impure thoughts for a moment. Open and read, out loud, what you just wrote down. Then look at the screen (or at the rod through the telescope) and confirm that you wrote it right.
If the outside temperature is more than about 10° different from the storage room temperature, and you are hoping for really tight closures, allow your level a few minutes to acclimatize before beginning work.
Posted : 21/09/2024 4:22 am
At all times you should imagine that there is a little leprechaun on your shoulder asking how you are f'ing up this time. And at all times you should be prepared to prove him wrong, a year in the future, with positive, documented proof. Conduct your work accordingly.
Posted : 21/09/2024 4:31 am
(@sergeant-schultz)
Noble Member Registered
3 hundredths per minute per hundred feet.
Posted : 21/09/2024 8:28 pm
GaryG
(@gary_g)
Honorable Member Customer
Use that flagging like you're not paying for it .
Posted : 21/09/2024 9:03 pm
(@la-stevens)
Estimable Member Customer
Minimize flagging or paint the stake around livestock. Flagging can kill an animal that eats to much.
Posted : 22/09/2024 3:09 am
(@jimcox)
Fluoro paint fades real fast. Plain enamel lasts MUCH longer
Posted : 22/09/2024 4:59 am
(@murphy)
Prominent Member Registered
Make an overt effort to appear courteous towards people's property. For instance, instead of cutting through someone's lawn, take the less direct route down a shared boundary or fence line. The neighbors are watching you out their windows. If they see you carefully replacing plugs of their lawn that you just dug up looking for an iron, it'll go a long way towards keeping the peace.
Posted : 23/09/2024 12:35 am
Check your backsight after having been set up for ±20 minutes. You will, most probably, find that it has drifted off. Reset the backsight at that time and it will "hold" for a good while.
If you are having trouble keeping the backsight reading consistent one of the possible causes is a worn tribrach. There are three little "bumps" on the tribrach plate that the instrument contacts. If these have become worn, relative to the clamping mechanism, the instrument will shift enough to throw off the backsight orientation. The only fix for that is a new tribrach.
Posted : 23/09/2024 1:22 am
If you are having trouble keeping the backsight reading consistent it may be because the tribrach has become worn. There are three little "bumps" on the tribrach plate that the instrument contacts. If these have become worn, relative to the clamping mechanism, the instrument will shift enough to throw off the backsight orientation.
Posted : 23/09/2024 1:24 am
(@hi-staker)
Reputable Member Registered
Just because your locator doesn't scream at a search point doesn't mean there isn't a rebar in the ground. I can't tell you how many "dead" rebars I have found by just probing with the shovel.
Posted : 23/09/2024 2:14 am
(@squirl)
"Look for old cut lines, old flagging. Surveyors leave a lot of different kinds of evidence."
AKA surveyor droppings
Posted : 23/09/2024 2:48 am
(@not-my-real-name)
Noble Member Customer
Before I stomp the shoes of the tripod legs into the ground, I take the instument off and put it in the box. Then, after the tripod is firmly set, I put the instument back on and finish the setup.
Posted : 23/09/2024 3:31 am
(@paul-landau)
Lots of great tips here, I’ll just say that, you will be amazed at how long flagging tied on barbed/hog wire will stay attached, just the knot. Keep your eyes open out there.
Posted : 23/09/2024 10:54 am
Page 2 / 3
Share:
