Record line is not bounded to a fence but landowner tells me the fence was always intended to be the boundary. How to reflect on the survey?
17 Users
(@vectormechanic)
Active Member Registered
The description contained in the deed is just "South 150 feet" but is several feet/degrees off the fence. Do I have them sign a notarized affidavit on the face of my ROS so I can use that information to place the boundary where intended??ÿ
Posted : 04/05/2022 8:13 am
No simple answer to that question.?ÿ Start digging through the chain of title.?ÿ The answer may be contained in the very first appearance of that 150 foot call.
Posted : 04/05/2022 8:47 am
(@kevin-hines)
Prominent Member Registered
Put the line where the historical documentation tells you it should be.?ÿ Don't put it on the fence unless the chain of title tells you that the line should be the fence.
Posted : 04/05/2022 8:54 am
Illustrious Member Registered
South 150' usually doesn't mean S00d00'00"E, 150.00', it normally will be found in the field to mean something between S03dW or S03dE, 145-155', somewhere in there and you're golden.
Adjoiner's deeds, occupation, chain of title, all those come into play, first thing is to lay out the history and geometry and figure it out. I wouldn't discount the landowner's statement, but I can't see an affidavit with this one. It's very typical.?ÿ
Posted : 04/05/2022 9:04 am
Have a new client because the Register of Deeds refused to record a deed with calls such as: northwesterly 112 yards; northeasterly, 304 yards; southeasterly, 654 yards to the east section line.
They had picked where the new corner posts were going to be set around a tract in two sections containing more than 200 acres using a rangefinder commonly used for spotting deer.?ÿ They couldn't understand why that could not be plotted by anyone in the GIS department.
Posted : 04/05/2022 9:09 am
First, have you polled the adjoining landowner for their opinion??ÿ
Oregon has a "parol evidence rule" which says that if the deed description is unambiguous it can't be altered by parol evidence. Which is what the landowner saying what his intention was would be.?ÿ I suspect that most states have a similar statute. Even if not it is a basic principle of common law.
So we move on to potential unwritten boundary agreements in their various forms - practical location, recognition & acquescence, etc.?ÿ Must be proven, not assumed.?ÿ
Then there is AP. Good luck with that.
Simpliest, cheapest thing for all is to move the fence. Next best is a (documented) boundary line adjustment.
Posted : 04/05/2022 9:17 am
 jph
(@jph)
Famed Member Registered
@norman-oklahoma?ÿ
I agree, but wonder the outcome if it ever went to court
Posted : 04/05/2022 9:30 am
Posted by: @jph
The outcome is that a couple of attorneys get to bill about $40k each.
Posted : 04/05/2022 9:34 am
Great! Please show me the document that says that, and I will be happy to use it as the basis of my survey.
If they can't produce the document (which is usually the case) then the next question is: "Who" intended it to be the boundary? A fence has 2 sides to it; if the neighbor has no recollection of that being the intention, then it's a one sided fence...
Posted : 04/05/2022 9:52 am
Posted by: @dougie
And if he does recall it a documented BLA is a routine matter.?ÿ
Posted : 04/05/2022 10:06 am
(@chris-bouffard)
Noble Member Registered
How did you determine where the documented location is??ÿ How far back does the original deed to the property go??ÿ Were the current owner and the adjoiner involved in the creation of the original transfer?
Posted : 04/05/2022 10:07 am
(@dmyhill)
Posted by: @vectormechanic
Had a similar situation. Owner kept telling me the fence was the boundary, but I was 15' short. He told me the fence (big RR ties set in the ground) had been there since before I was born. When I found the rebar with caps that matched the short plat, I was pretty happy.
But, it depends on your state. In some states, if both neighbors agree, then it is simple boundary line agreement signed by the parties.?ÿ I would not think that the statement by one of the parties would be enough to "move" the line.
Posted : 04/05/2022 12:17 pm
(@kevin-hines)
I've always been of the understanding that a Boundary Line Agreement was only valid if the actual line was not able to be determined and placed on the ground. If the line is recoverable, then a quit claim deed would be required to convey all interests, if any, to the piece of property between the boundary line and to the fence. I've heard this from my mentors on my way to licensure and from Don Wilson in his seminars. I would think this would be a universal throughout the US, but that is just my guess that isn't supported by fact. If my memory serves me correctly, it has to do with the Statute of Frauds. I'll have to look it up now....
Posted : 04/05/2022 1:24 pm
(@fairbanksls)
No.
Posted : 04/05/2022 2:30 pm
(@frozennorth)
Honorable Member Registered
Posted by: @kevin-hines
Surveying scholar @dave-karoly gives these definitions (from this old thread https://surveyorconnect.com/community/surveying-geomatics/subjective-uncertainty-v-objective-uncertainty/?ÿ ):
"Subjective Uncertainty?ÿis in the mind of the property owners, e.g. they don't know where the boundary line is located. If it can be surveyed or the deeds are unambiguous is irrelevant.
Objective Uncertainty?ÿis a stricter standard. If the property can be surveyed or the deeds are unambiguous then the boundary line is not objectively uncertain is my understanding of it."
This is an important component of what Jeff Lucas often teaches regarding boundary law..
Posted : 04/05/2022 2:40 pm
Share:
