Property Line Width
37 Users
(@rich)
Prominent Member Registered
"How wide is a property line? Like 6 inches?" - Mr. Architect trying to figure out how close he is to a setback requirement.
Quite amazing.
Posted : 29/10/2016 1:05 pm
It depends. How wide do you want it to be? Need to know that before I give you the estimate you're asking for.
Posted : 29/10/2016 1:45 pm
Illustrious Member Registered
Is it a stone wall?:cool:
Posted : 29/10/2016 1:46 pm
(@dave-lindell)
å±15 cm in Singapore.
Posted : 29/10/2016 1:54 pm
Most every time I've had to tell a client that their house will not fit on the property they tell me an inlaw or buddy drew them up and could not be wrong because they are college graduates with an architect degree.
In every case their buddy contorted the boundary to fit their drawing.
Then their buddy comes out with "a good builder can make that fit with no problems".
:bomb:
Posted : 29/10/2016 1:56 pm
(@grant-brady)
Estimable Member Customer
According to my old surveying buddy Homer when a client ask that very question:
"The two sizes are soooooo close together they almost overlap!"
Posted : 29/10/2016 8:04 pm
(@john-birner)
Active Member Registered
Mabe if they paid you more money, you could refer them to a good GIS database
Posted : 29/10/2016 9:18 pm
(@john-putnam)
Noble Member Customer
Lines are one dimensional by definition. I guess you could make a case that the width is based on the accuracies of your measurements. Even with that I would guess that the setback line would be held to center of the width.
Years ago I started on a property line adjustment of several 100 year old lots. The city rejected the owners application because the plat record 100 foot width turned out being 99.5 feet on the ground. As a point of irony, he could though go through the partition process (way more cost) and split his 2 lots into 3 with out any problem.
Posted : 30/10/2016 11:43 am
(@flga-2-2-2-2-2-2-2-2)
Rich., post: 397466, member: 10450 wrote: "How wide is a property line? Like 6 inches?"
Explain to Mr. Architect that it's imaginary and has no width.
Please let us all know how that went. :p
Posted : 30/10/2016 1:34 pm
(@rich)
John Putnam, post: 397562, member: 1188 wrote: Lines are one dimensional by definition. I guess you could make a case that the width is based on the accuracies of your measurements. Even with that I would guess that the setback line would be held to center of the width.
Sounds like around here.
Posted : 30/10/2016 2:01 pm
(@rich)
FL/GA PLS., post: 397571, member: 379 wrote: Explain to Mr. Architect that it's imaginary and has no width.
He wanted to know if it had width 'which side we measured to' [emoji44]
Famed Member Registered
Show me an architect that will ask a question like this and I'll show you an architect that has fouled up big time and is now grasping at straws.
Posted : 30/10/2016 2:16 pm
"While a presumption does exist that if a natural monument has width, then the boundary is the centerline of the monument, this presumption is rebuttable and does not replace the canon that the intent of the parties is determinative. Porter v. Bassett, 146 Idaho 399, 195 P.3d 1212 (2008)." å¤ 198.Monuments, courses, and lines, 11 C.J.S. Boundaries å¤ 198
Posted : 30/10/2016 5:55 pm
(@mike-marks)
Noble Member Registered
The width of a property line is exactly zero. Measurement of the line introduces instrumental error ellipses, but is resolved by the surveyor's adjustments and opinion. Once resolved by a ROS, subdivision map or corner record the line has no width, the definition of a line.
Posted : 30/10/2016 7:07 pm
(@dan-patterson)
Any width other than 0 would imply a gore in my opinion...
Posted : 30/10/2016 8:03 pm
Page 1 / 5
Share:
