POB magazine folds operation
23 Users
(@mike-marks)
Noble Member Registered
Posted by: @bill93
Posted by: @mike-marks
I'm suspicious the northern half of the of the property is 19 acres, not 18.?ÿ
If it was a nominal 40 then it is probably PLSS and half would likely still be worded as an aliquot part.?ÿ Depending on the shape of the section, the 1/2 1/4 1/4 out of a 38.00 acre 1/4 1/4 might not be exactly 19.00, either.
I'm aware some States require following BLM procedures when further subdividing PLSS parcels even when in private hands, but most(?) States consider PLSS land when patented no longer subject to the BLM Manual's procedures concerning further subdivision.?ÿ So if this client says he wants his 40 acres split exactly in half by acreage I'd create an E-W boundary on the mean of the North and South boundary lines and both new parcels would encompass 19.00 acres, even if the parent deed is described as a PLSS aliquot part.
Some caveats here to calm raised hackles:
  • If any parent parcel boundary abuts unpatented Federal Lands, Indian Reservations, military bases, etc., since there's still a Federal interest any rehabilitation of that boundary must follow the BLM Manual. Obviously reasonable.
  • Many(?) States that do not require adherence to BLM procedures for further subdivision require that any obliterated/lost PLSS corner be rehabilitated using BLM rules, no matter if it's an internal corner or common with adjacent private landowners.?ÿ Reasonable in that such a PLSS corner may control parcels beyond the subject parcel.
  • I'm a proponent of the "subdivide however you wish" once patented; Federal interest has?ÿ been extinguished and the owner should only be subject to County and Municipal strictures.
  • The PLSS system was designed to sell Federal lands en masse both to fill the Treasury and get land in the hands of citizens for development.?ÿ It's intent was not to limit further subdivision be in smaller squares and rectangles ad nauseum.?ÿ So once severed the Feds should get out of the way and let further subdivision be under local control.
  • The contrary may be shown.?ÿ If the owner says he wants to sell the SW 1/4 of his 40 acre patented parcel I'll dutifully break down the parcel using BLM procedures and acreage will be more or less.?ÿ Reasonable in flatland farming scenarios.
  • In reality I mostly worked in rural small parcels (<40 acres) where the owner knows exactly what he wants to sell, is surrounded by private ownership and walks me through his wishes; west of this County road to the swamp, then skirting it to to the cliff base et. al.?ÿ I've actually given a coupla rolls of flagging to owners and surveyed the dividing line they set for the new boundary.?ÿ Nothing to do with the SW16th of the NW14 blah-blah.?ÿ His PLSS patent is irrelevant except to control his original exterior boundaries.
Posted : 29/07/2021 12:35 pm
(@jitterboogie)
Famed Member Customer
@mike-marks?ÿ
Thank you, that's an awesome answer, I love the stuff I get to learn about here.
Posted : 29/07/2021 12:44 pm
Page 3 / 3
Share:
