Need advice acquiring a data collector
Famed Member Registered
Hi all:
Well, after 8 years of use, the prehistoric JettCE data collector I purchased from a longtime member here for $200, finally bit the dust. Many of the keys did not work, but I got by with just the touch screen (which has now gone wonky). I'd try replacing the screen, but can't even find them anymore on ebay. It was running SurvCE 2.07, and had TS and GPS enabled; I've only used it with my total station, using a db9 connection. I understand that I can get an adaptor for my Topcon TS if needed.
So, I need advice. As some of you may know, I'm not a professional; don't survey for a living; have only been teaching myself slowly over the years. I'm looking to replace my DC with a mere antidilluvian unit. ?ÿAs such, I simply can not afford $2000+ for anything near recent in manufacture and support. I'd like to find something for a budget of less than $400-$500 in mind, but am finding it challenging to know where to look and what to look for. Here's what my research has found so far:
Carlson Explorer 2's: Available for $200+/-, but seem to be older than mine; running SurvCE 1.67 or so. Is there much in 2.07 that I'd miss in 1.67?
Carlson Surveyor: Most seem to run SurvCE 6.01 or higher, but run from $600 all the way to $2000+
Juno T41/5...SurvCE...$600+/- Don't know much about Juno's. Juniper's: ditto.
Other than that, I found some Getac's, like the PS336, again for $600, but some with not just SurvCE, but Survey Pro, Field Genius etc. Some come from Romania and include all kinds of warning about the software licenses...sounds bootleg to me.
All I want is something that works; Don't need anything but TS, and uncertain about what if anything a higher version of SurvCE will do (although my 2.07 has seemed kind of klunky at times, but not sure it doesn't just have to do with the hardware).
There just doesn't seem to be much out there between the low end (Explorer 2) and more recent (5-10 years) units. ?ÿI've checked the Marketplace here without much luck.
Any advice on what I should be looking for given the knowledge I an not a professional and willing to settle for less than stellar performance (although I still love to "do stars", but don't need a DC for that lol), is very much appreciated. If any here feel inclined to clean out the old equipment closet, that would work too.
Many thanks in advance.
Posted : 05/07/2023 5:11 am
Maybe you could find a TDS Trimble Recon Controller running Survey Pro in that price range if all you're running is a total station with it. There seem to be plenty around. I have one on the shelf but it isn't for sale.
Posted : 05/07/2023 2:08 pm
I'd really like to stick with SurvCE, as that's what I've learned.
Posted : 05/07/2023 3:51 pm
Update:
I fixed mine! Praise the Lord! I noticed that when using a stylus (rather than my fat fingers or a pencil eraser), I could make the window scroll bar move by placing the stylus all the way to the right of the screen. This allowed me to scroll down to the computer settings icon and then found a touch screen calibration menu item.
Recalibrated the screen and all is good.
i’d still appreciate opinions on any of the hardware noted in my first post, for future reference.
Posted : 09/07/2023 1:50 am
(@toeknee)
Trusted Member Registered
I bought a Panasonic FZM1 Tablet with SurvPC on it from Romania.  The tablet was in great condition.  The SurvPC on it was indeed bootleg and had all sorts of problems.  I ended up reinstalling Windows and buying a real copy of SurvPC from a dealer here in the US.
Posted : 28/07/2023 6:40 pm
Share:
