Need a simple phrase...
22 Users
 BSA
(@bsa)
Estimable Member Registered
I need a simple phrase to discount the idea of using a distant object to "control" boundary location.
Posted : 12/05/2017 12:31 pm
(@flyin-solo)
Noble Member Registered
the price of tea in china?
Distances from opposing control points are subject to a degradation of accuracy that increases with the length of vector.
Posted : 12/05/2017 12:36 pm
(@andy-nold)
I don't know but I sure got a laugh out of that "fornicate with frogs" phrase proffered in another thread.
Posted : 12/05/2017 12:39 pm
(@dave-lindell)
The buck stopped over there. Leave it there.
Posted : 12/05/2017 1:12 pm
Illustrious Member Registered
"You can't see it from here."
Despite the phrase a distant object may be the strongest and possibly the only extant call.
Posted : 12/05/2017 1:39 pm
(@steve-gilbert)
Keep the errors contained!
Posted : 12/05/2017 1:58 pm
BSA, post: 428109, member: 1122 wrote: I need a simple phrase to discount the idea of using a distant object to "control" boundary location.
Question is a bit vague, can you elaborate?
Posted : 12/05/2017 2:51 pm
leave sleeping dogs lie...
Posted : 12/05/2017 3:25 pm
Beginning at an iron shaft in the intersection of Murphysboro Pike and Turner Lane, thence seven miles along said Murphysboro Pike to the point of beginning; thence.................................................
Is the argument that the iron shaft is the definitive portion of the overall description?
Posted : 12/05/2017 3:34 pm
"Them CORS antennas is pure bunk and they all refer to some point way inside the Earth that no one has ever seen," would be one.
A more serious one, if the real problem is boundary retracement "The problem inherent in using some bearing and distance calculated from a remote point from the records of early surveys to re-establish some corner is that experience shows it invariably to be less reliable than a method that relies upon evidence nearer to the corner in question that would tend to show the locations in which lines were actually run and corners actually marked."
Posted : 12/05/2017 3:53 pm
64 words a simple phrase do not make.
Posted : 12/05/2017 4:00 pm
(@bk9196)
And how could the owner reasonably taped an accurate location from that monument
Posted : 12/05/2017 4:26 pm
Holy Cow, post: 428146, member: 50 wrote: 64 words a simple phrase do not make.
Alrighty then, how about "That dog don't hunt". I have a few boiler plate phrases that I've used more than a few times on various matters. In the era of cut-and-paste, brevity isn't always required.
Posted : 12/05/2017 4:28 pm
A perfect world where surveyors were able to measure long distances without appreciable errors has only existed in West Virginia in modern times. Before then, it was anything but.
Posted : 12/05/2017 4:30 pm
Page 1 / 3
Share:
