Long Backsight or long resection
16 Users
(@nettronic)
Trusted Member Registered
Choices are, a long backsight with a traverse to a flat angle or.. setup and shoot in two known points (the long backsight)
My boss is much smarter than me and confuses me all the time. Which is better, a long baseline with a flat angle. Or setup in the middle and double angle to the ends?
Posted : 01/10/2021 8:54 pm
Illustrious Member Registered
Both is better
Posted : 02/10/2021 12:36 am
(@jonathan50)
Estimable Member Registered
What's a flat angle?
Posted : 02/10/2021 1:18 am
(@nettronic)
Nearly 0
Posted : 02/10/2021 4:35 am
 jph
(@jph)
Famed Member Registered
I'd go the long BS. If possible, a POL, where I don't touch the H tangent screw, so I wouldn't double the angle either.?ÿ
But I wouldn't have an issue setting a point at near 0.?ÿ
When you setup on the new point, after you BS, turn to the original BS and shoot that in as a check
Posted : 02/10/2021 4:50 am
Posted by: @nettronic
Nearly 0
When you measure both angle and distance with comparable accuracy there is no bad angle to use in a traverse.
You can't accurately resect from points without reasonably angular spread.
Posted : 02/10/2021 5:13 am
(@john-putnam)
Noble Member Customer
You can not reliably resect off of two points with any level of confidence.?ÿ Don't get me wrong, Resections have their place it is just not the first tool to bring out of the box.?ÿ Besides, I don't think modern digital total stations have the problems associated with flat angles their glass plate theodolite predecessors had.
Posted : 02/10/2021 6:52 am
No matter what you do, ALWAYS check what you do.
And read everything you can get your hands on; written by Dr. Ben Buckner.
Posted : 02/10/2021 7:37 am
(@mike-marks)
Noble Member Registered
Posted by: @john-putnam
Educate me.?ÿ Why would any angle, including a "flat" one, be measured less precisely by a T2 compared to a total station?
Posted : 02/10/2021 8:09 am
Are we talking about a "wiggle-in" here? (or something similar)
Posted : 02/10/2021 8:30 am
Posted by: @bill93
This is a misconception that I held for a long time until someone challenged me on it and I ran a Star*Net preanalysis to check.?ÿ As long as you're including distances in the resection, you're actually better off being close to the line defined by the two control stations (flat or shallow angle) than you are being offline (large angle).
In the following diagram, points 1 and 2 are fixed (no error).?ÿ Points 3, 4 5 and 6 are resected points.
t
Using the default Star*Net standard errors and the preanalysis function, here are the resulting error ellipse values:
                   Station Coordinate Error Ellipses (FeetUS)
                            Confidence Region = 95%
Station              Semi-Major    Semi-Minor   Azimuth of       Elev
                               Axis                Axis            Major Axis
1                         0.000000      0.000000        0-00                  0.000000
2                         0.000000      0.000000        0-00                  0.000000
3                         0.015811      0.010297        0-00                  0.010435
4                         0.014625      0.010273        0-00                  0.010260
5                         0.034726      0.013410        0-00                  0.013984
6                         0.014869      0.012963        0-00                  0.014585
The smallest errors lie with the points closest to the control line.
Posted : 02/10/2021 8:32 am
Posted by: @bill93
I was wrong about resection. See Jim Frame post below.
Posted : 02/10/2021 8:41 am
Resection is angles only?
Including distances is sometimes called Freestation.
Posted : 02/10/2021 8:54 am
(@john-putnam)
@mike-marks?ÿ
Personally, I've never understood the hesitance turn flat angles.?ÿ
As for the precision of angle measurements between a modern MS60 and a T2, while they may both be 1" instruments they have differences in sources of non-random reading error bas on how they obtain their angle measurements.?ÿ The T2 used an angular gradient imprinted on a plate.?ÿ The plate was a possible source of non random error.?ÿ To minimize the error, you would turn multiple sets of angles, re-zero the T2 in different quadrants of the plate between sets (DBS-DFS-RFS-RBS, new quadrant and repeat).?ÿ Modern total station utilize digital incoder for reading the angles and does not have a plate per say, minimizing that possible source of error.
Posted : 02/10/2021 9:02 am
The first concern is always eliminating blunders. It is the blunders that get you in trouble. Lack of precision can be a bit embarrassing but that is about as far as that will go in most cases.
Resectioning is very powerful, and, done correctly, aught to work just fine. But it is also very easy to screw up. The statistics that your dc returns for a resection are somewhat more complicated than for a simple backsight check. Not rocket science, but somewhat more complicated. So it is probably a phobia about screwed up resections, and not a serious concern about precision, that has your boss resistant to them.?ÿ Personally I use resections routinely but I have a rule to always use 3 control points. An error in a 3 point resection is likely to cause it to outright refuse to resolve, thus reducing the chance of a blunder being perpetrated. I will bend my rule and use 2 points in a low leverage situation when I'm doing it, personally. But people that work for me must use 3 points until I'm 100% confident in their ability to understand the statistics, and their willingness to review them in a timely manner.
Finally, the "flat angle" thing is a throwback to the days of open vernier transits which read angles to the half-minute. It's not really a thing to concern yourself with when using a half-way modern total station.?ÿ
?ÿ?ÿ
Posted : 02/10/2021 9:21 am
Share:
