LGO Closed Traverse, sample practice
1 Users
(@bmarco)
Active Member Registered
Hi all,
Trying to learn the basic of Leica Geo Office and trying to practice a little. I have a closed traverse not undertaken by myself. Ground local coordinates, factor scale 1
G1 set azimuth on G2
G1 forsight S1 and S3
S1 forsight S2 and M10
S2 forsight  S3
S3 foresight G1
Each target has been shot 6 times (3 on both faces).
I create a new traverse, add the stations, calculate and i get :
"Angular and closing misclosure could not be calculated due to missing Control coordinate or unknown azimuth for last forsight azimuth". no matter which method I use
I notice that at S1 it recognise as " Foresight Point Id" M10 that is not a vertex setup of the traverse so I changed it with S2, it shows me all 6 triplets, it doesn't matter which one I choose.
Anyway nothing changes.
Then I set S3 as Control (fix Pos and Height).  and now traverse recalculate works.
Now the question is...Why? Setting S3 as control, I fix it and it is not affected by the adjustment. Is that right?
I also tried to set as control G2
Or the problem is in the state (never,always,automatic)?. I'm pretty confused about this also.
Thanks
Edit:
"I also tried to set as control G2"  I was wrong. I have to set S1 and S3 as control other wise it doesn't recalculate the traverse.
Posted : 22/08/2023 10:47 am
Share:
