What i want is simple : an ASCII output with Best class point only. So for example, i will get all points, but if i measured 3 times the same point #200 and an average point was created, the best class will only export the averaged point.
But when you do a setup, such as a resection, it will import the control point from the reference job. Control point is the highest class, so when i will export my ASCII, the control point will have precedence and i wont have a coord for my observation.
I can manually delete the control points in the View data page, which will reveal the observation afterward. I can also semi manually filter the points in that page by choosing Filter > Show only select point class > set «Hide» to all classes except Control > OK and then click «Fn + All» to select all control points, and then i can delete them all at once. The filtering process is quite tedious.
Is there a better way to acheive this? or automate this?
(Yes i could delete them easily with Infinity but i hate that software)
I can't believe i'm the only one who wants quick observation coords without the control points...
