How to describe trees with "two or more trunks"
25 Users
 Jed
(@jed)
Estimable Member Registered
We always record DBH and drip radius.
Species, DBH of all trunks, drip
Posted : 26/05/2021 11:13 am
I avoid such work like the plague.?ÿ Unless it drops an apple on my head it might be anything but an apple tree.?ÿ One surveyor says it's an elm and a different one says it's a hackberry and it is definitely the same tree.?ÿ I gave up on that years ago.
Posted : 26/05/2021 11:25 am
(@dmyhill)
Famed Member Registered
@bushaxe
Around here, municipalities provide guidance on how to measure and describe those sorts of things. Fortunately, they are all different and change every couple of years.
Posted : 26/05/2021 12:32 pm
(@bstrand)
Noble Member Registered
On a tree like that I'd probably just shoot them separately.?ÿ
Posted : 26/05/2021 4:35 pm
(@samlucy3874)
Trusted Member Registered
Dang good question,?ÿ I have used all kinds of descriptions for these.
My toughest thing has been labels or do you give a written narrative with pictures, this has been my go-to way as of late. Show point numbers on drawing with some symbol and then include a written explanation with pictures for the client. Plats get so busy with notations. Required certifications.
Can the client actually figure out what parcel we actually have surveyed.
Posted : 03/06/2021 4:38 pm
(@dave-o)
Honorable Member Registered
@holy-cow ahh, and I thought @rankin_file was recording a shot he took on an oddly proportioned teacher.
Posted : 03/06/2021 4:47 pm
(@bobwesterman)
Reputable Member Registered
Posted by: @nate-the-surveyor
24" & 32" twin white oak
24" & 32" & 36" triple white oak
I've always had a problem calling them twins if the trunks aren't at least close to the same diameter.
I would call it 24" & 32" double white oak.
Posted : 03/06/2021 6:40 pm
(@epoch-date)
M3 10-8-6" OAK 28'
Posted : 04/06/2021 2:39 pm
(@tim-libs)
I have it set up in Civil3D in the description key set to automatically scale and describe the tree based off the field call (to an extent). In your situation Iƒ??d measure the base of the trees total diameter to accurately plot its footprint, then measure each trunk at 48ƒ? above the ground (breast height) for the correct labeling of each trees size. I used to average them, but when you start getting into big clusters the size doesnƒ??t accurately scale compared to its footprint.
TWNC 30 F 24 F 20, plots a twin conifer symbol with a 30ƒ? diameter footprint, and lets me know to label it a 24ƒ? Fir and 20ƒ? Fir.
TWND = Twin deciduous
CLUC = Cluster of Conifer trees
CLUD = Cluster of deciduous trees
Posted : 04/06/2021 9:50 pm
(@murphy)
Prominent Member Registered
I was told by a forester that the correct term is bifurcated.?ÿ I code most points including trees, so my code always begins with a "T".?ÿ In this example "T Oak28-26 Bif".?ÿ
North Carolina has 29 species of oaks and I can only identify about eight without a guide.?ÿ If I know it's a live oak I'll add that to the description too.?ÿ?ÿ
Posted : 05/06/2021 2:40 am
Famed Member Customer
Stump.
Posted : 05/06/2021 7:21 am
 jaro
(@jaro)
What would you call this one?
NCM 0796
Posted : 05/06/2021 10:40 am
@jaro
Well, now,?ÿ you see, I would call that a "lady" tree.?ÿ If a limb had sprung forth a short distance above the joining of the "legs" and then been sawed off some distance outward from the trunk(s) and died, it could be called an "old man" tree
Posted : 05/06/2021 11:01 am
(@2xcntr)
@bobwesterman
Umm, not where I went to school.... Nate has it correct.
IMHOTI
Posted : 05/06/2021 2:32 pm
Share:
