PEC; can't say I've seen this one before, have you?
I tried to find it on the BLM website with very little success. I did find this:
It seems, Isaac Pincus acquired 95.9 acres with a serial patent, in 1873.
This has no real bearing on my survey; just curious as to what it meant, in 1873.
TIA to all the good people on this board; you guys are the BEST!
Dougie
I see "Rec'd with letter" inked in red on the original GLO plat if that is to what you are referring.?ÿ?ÿ
What I'm trying to figure out; what does P.E.C. stand for?
I see the note about the letter, maybe that's where I'll find my answer...
Preemption claim??ÿ
@dougie?ÿ
I guess my eyes are worse than I thought.?ÿ I can't find an acronym "P.E.C." on the map.?ÿ I guess if it were a snake, it would have bit me by now.
I apologize, I didn't see it on the old map either. It shows up on the Assessor's map, several surveys and deeds...
@dougie?ÿ
I see PEC and DLC following a few names on the Assessor's map. I'd contact the assessor's office to see if they could explain.?ÿ I'd venture a guess that PEC would be Patent Entry Claim & DLC would be Deed Land Claim, but I'm just spit-balling here.
@kevin-hines The acronym DLC stands for Donation Land Claim.
@dougie I've never seen P.E.C. either. I didn't see any mention of it on the patent or the diagrams and supplemental plats for T. 20 N., R. 2 E., Willamette P.M.
DLC is pretty common; I think @blitzkriegbob is probably pretty close...
@dougie The patent says that the four lots (6-9) were patented under the authority of the Act of April 24, 1820. I'm not that savvy about the various rules for disposal of the Public Lands under a preemption claim, so you may be correct.
Found it here.?ÿ Pre-emption Claim
https://www.piercecountywa.gov/DocumentCenter/View/31123/Abbreviations-For-Legals?bidId=
Wow! Thanks Holy!
Took somebody from Kansas; to figure it out...
Learn something new everyday!
Dougie
Happy tuh hep ya out.?ÿ
That googlesearch thing is tricky.?ÿ Sometimes you have to search for really weird things to find something normal.
