FLAT EARTH SURVEYOR, seriously?
51 Users
Famed Member Registered
Dale Yawn, post: 440672, member: 492 wrote: OK, if the Earth is flat, then where is the edge?
Dale Yawn
Savannah, Ga.
Well....the edge is on the other side of the globe. I thought everyone knew that.
Posted : 08/08/2017 5:44 am
I have been to the west edge numerous times. Not sure where the east edge is located. My guess it is close to where the maps indicate sea dragon territory.
Posted : 08/08/2017 5:53 am
(@john-putnam)
Noble Member Customer
After $70K in cartography and surveying lessons, my wife just informed me that cats are prof the world is not flat. If it was, they would have pushed everything off of it by now.
Posted : 08/08/2017 6:02 am
(@makerofmaps)
Prominent Member Registered
Is he from the Molodensky or the Helmert flat earth society?
Posted : 08/08/2017 10:11 am
(@wildt2)
Reputable Member Registered
Walter Bislin messaged me on my channel to send me this pretty cool simulator -
Flat-Earth: Finding the curvature of the Earth - Waltis Blog - Walter Bislin
http://walter.bislins.ch/blog/index.asp?page=Flat%2DEarth%3A+Finding+the+curvature+of+the+Earth
Sent from my SM-G950U using Tapatalk
Posted : 08/08/2017 2:43 pm
(@larry-scott)
Noble Member Registered
JOHN NOLTON, post: 440493, member: 225 wrote: Well the question above on the video is "DOES THE SUN CHANGE SIZE"
Every surveyor should know that the answer is YES ( and NO).
If you measure the Sun diameter from Earth the diameter does change due to the orbit of the Earth .
Perigee (nearest) of the Sun and Earth happens on 4 Jan 2017 and Apogee (farthest) of the Sun and
Earth happen on 3 July 2017. The semi-diameter of the Sun at Perigee is 16' 15.93" and at Apogee
the semi-diameter is 15' 43.90".
Now if you measure the Sun Diameter at a constant distance or take in consideration the orbit of the Earth
the Sun does not change in size.
JOHN NOLTON
This guy's citing change of size during a single day. He's only measuring digital camera images. And he's coming up literally a few pixels different. And he's not being methodical. Near the horizon the sun's vertical size is squashed a small bit. But as we know the horizontal dimension is constant in any one day. At least he's not arguing that it changes by large percentages, and if he just addressed the horizontal component he'd find it the same.
The worst part is he says his observations demonstrate a small, nearby sun. That's just messed up. But I suspect he may just be doing it for clicks.
He's odd. But in the flat earth club, he's a bit on the tame side. More of a Dunning/Kruger syndrome behavior.
Posted : 10/08/2017 7:24 am
Illustrious Member Registered
Don't worry about the flat earthers....
They will fall off the edge, one of these days!!!
Posted : 10/08/2017 7:34 am
(@andy-j)
Reminds me of the surveying experiments the Koreshans did here on Ft. Myers Beach trying to prove that we lived on the INSIDE of a hollow earth! Now those people were wacky! They actually made their own sort of equipment trying to prove if you leveled far enough the measurements would prove their theory.
https://en.wikipedia.org/wiki/Koreshan_Unity
Posted : 10/08/2017 9:39 am
(@andy-j)
http://www.lhup.edu/~dsimanek/hollow/morrow1.htm
Posted : 10/08/2017 9:53 am
If we could just pass the legislation, we could MAKE the earth flat. This would eliminate alot of survey problems. Scale factors, coordinates, no longer need Lat Longs, and building a GIS becomes much simpler. It should be a law. And, all those who oppose it should be labeled non progressive, and ignerant.
Makes sense to me...
Posted : 18/04/2018 4:11 am
moon
Here is a pic of the change it will make. But, the shape of the moon is not that important...
Posted : 18/04/2018 4:16 am
(@iceman)
Estimable Member Registered
I started surveying in 1974. I did not do any geodetic surveying, except for once, a railroad tunnel, pusher terminal in Golden, British Columbia.
Except for that, chaining, topo, with rag tape, station and offsets, and levels.
Ran the line, or parallel, so no coordinates needed, or assume with 100' elevation.
No GPS.
I think life was easier when the earth was flat.
Posted : 18/04/2018 5:15 am
What really amazes me?ÿis the number of people that attempt to clear dawdling sheep from a roadway by getting out of their car to reason with the livestock. ??ÿ
Posted : 18/04/2018 6:04 am
(@eapls2708)
Posted by: Dale Yawn
Dale Yawn
Savannah, Ga.
No one really knows because those who get to the edge fall off... but not really.?ÿ They actually end up falling onto the other side of the flat earth where most people also laugh at flat-earthers.?ÿ Those who make it back are the ones everyone writes off because they claim to have visited an alternate universe, not realizing they just fall back across the edge rather than stumbling upon a super-cosmic portal to the other universe.?ÿ Those are the real dummies for thinking they flew through time and space instead of simply experiencing a terrestrial coin flip.
Posted : 18/04/2018 10:46 am
Posted : 18/04/2018 12:03 pm
Page 3 / 7
Share:
