Diagram A - crawlspace
Item A8. a) Square footage of crawlspace or enclosures
This structure has a front porch that has a crawlspace that is separated from the main crawlspace by a block wall. They are looking for the total, right?
Thanks
Yes BUT, I make copious notes describing the situation, you might even say I make a plethora of notes.?ÿ
I would clarify in my notes there are two crawlspaces.?ÿ There is the primary crawlspace for which a specific number of square inches of openings is the minimum and a second crawlspace for which a different number of square inches of openings is the minimum.?ÿ Plus, there needs to be a minimum of two openings for each crawlspace to allow inflow/outflow.?ÿ The depth of the crawlspace may be quite different also, so that should be noted.
