Hello folks,
I am extremely baffled as to why my TSC3 controller can't connect to my SPS 930 via radio. I am positive that I have all the radio channel and network ID settings correctly entered on the SPS 930. I am able to connect via Bluetooth, however this is no good in the field where I often need to be hundreds of feet away from the total station.
I have tried connecting via radio in both siteworks and SCS 900, with no luck.
Has anyone else had an issue connecting to the SPS 930 via radio? If so, could you kindly share with me how you resolved the issue?
Thank you so much!
Tony
Does the TSC3 have a 2.4ghz radio installed? I don't see an antenna sticking out from the top of the controller. Provide a picture of the back of the controller if your unsure.
Yeah, even if the radio module is installed, you're still gonna need that antenna...
Thank you so much R S Mayer! You have cleared it up for me! I assumed the TSC3 had an in-built 2.4ghz radio, but it does not. It totally would have had an antenna if that were the case!
Thanks again!
