Coding in Survey Pro
(@richcritch)
Hi All,?ÿ?ÿ
I've been having an issue coding points.?ÿ The survey pro software asks me for the mandatory attribute (e.g. Stone for a wall line), every single shot.?ÿ I can't find anything where I can turn this off, and the survey pro manual says that it should only ask on the first shot of a line attribute.?ÿ I've checked the FXL file in the feature definition manager, and that shows they're all line codes, so I can't figure out why this is happening.?ÿ Any ideas?
Rich
Posted : 10/09/2019 11:43 pm
(@freefallin1309)
Home screen>Settings>Surveying(in drop down menu or Tab over)>uncheck Prompt for Code and Attributes
Posted : 11/09/2019 7:46 am
(@richcritch)
@freefallin1309
Hi,
Thanks for the advice.  That box is unchecked though.  Does anyone have any other ideas?  It's prompting me because it's mandatory - "Required" in the .fxl, but then asks me to confirm it each shot.  It remembers that it says "stone" or whatever, but insists that I confirm it every shot which is incredibly annoying.
Incidentally, has anyone had any trouble with codes not appearing for no reason?  Using the Feature Definition manager, if you delete them out and put them back in, they appear.
Posted : 12/09/2019 1:32 am
(@standing-on-the-corner)
Modify the .fxl?
Posted : 12/09/2019 2:30 am
(@richcritch)
Do you mean make it so they are non-mandatory?  I don't really want to do that as it'll get forgotten about and not used.  Thanks though.
Posted : 12/09/2019 2:48 am
