Cheaper than a shiner
15 Users
(@david3038)
Reputable Member Registered
D21162EB 23D9 421A B44F D0C716897336
Posted : 15/12/2022 12:13 pm
Illustrious Member Registered
Back in the '90s the place I worked for used concrete nails instead of PKs because PKs were too expensive. I would drive them through pennies just like that. The boss complained about the cost! I assured him that the pennies were coming out of my pocket, not his. He figured he must be paying me too much.?ÿ?ÿ
Posted : 15/12/2022 12:54 pm
(@dgm-pls)
Pennies cost a little over $0.02 to mint...and a nickel costs about $0.08 to mint.?ÿ So Using a penny you get a pretty good subsidy when you use it for something else.?ÿ Just a thought.
Posted : 16/12/2022 5:18 am
(@andy-bruner)
Famed Member Registered
And pennies get "shinier" the more they get run over.?ÿ We also used concrete nails, before I had ever heard of a Magnail.
Andy
Posted : 16/12/2022 5:39 am
I've never seen that before!!?ÿ
Thanks for posting!!
Posted : 16/12/2022 5:41 am
(@flga-2-2-2-2-2-2-2-2)
The kind of shiners I use cost about $1ea. ?????ÿ
download
Posted : 16/12/2022 5:47 am
Modern pennies are mostly zinc with only a thin veneer of copper that will wear away quickly. Older pennies of mostly copper are getting rare in the wild because they have about $0.03 worth of copper in them, melt value.?ÿ
Posted : 16/12/2022 12:10 pm
(@andy-bruner)
Yeah, but 50 years ago I don't believe we were too worried about the melt value.
Andy
Posted : 16/12/2022 12:12 pm
(@jon-payne)
Noble Member Registered
Way back, we used to use the caps from be...soda.?ÿ Probably much more expensive than just using a penny, but they were a lot more fun to get!?ÿ For some reason, that was one stock item that never seemed to run low.
Posted : 16/12/2022 12:56 pm
(@gromaticus)
I came here looking for an inexpensive way to avoid a black eye.
I am disappointed...
Posted : 16/12/2022 1:29 pm
(@olemanriver)
Copenhagen lids and beer coke soda bottle lids is what we use to use. ?ÿI had a cousin way older than I he was electrician so he use to bring me the circle punch outs in a old paint bucket. I would use a press drill and punch a small hole in center and stored them in the truck. But that was in 90ƒ??s.?ÿ
Posted : 16/12/2022 3:20 pm
(@stlsurveyor)
"Nail w/Bottle Cap" are quite common reference points for ties around here. I always use Shiner caps...pun intended, and Shiner Bock is my favorite brew.
https://shiner.com/brewery/spoetzl-brewery
Posted : 16/12/2022 7:51 pm
One now-deceased, local surveyor used bottle caps regularly with his reference nails.?ÿ The nails were cheap as they were so small
Posted : 17/12/2022 9:20 am
(@jaccen)
This was also quite common when retracing old Trans Canada Pipeline surveys.?ÿ You would find the traverse control points called out:
#1 "BLUE"
#2 "OV"
#3 "L50"
#4 "BUD"
It also seems like 1/5 of the vertical benchmarks set in the 60's in Toronto were, rather conveniently, always set into the foundation of a Beer Store.
https://www.thebeerstore.ca/
Posted : 19/12/2022 3:31 pm
(@david3038)
@mightymoe First time for me too
Posted : 20/12/2022 7:46 am
Share:
